Embedded map not displaying
899
09-02-2025 01:09 PM
BrandonGauchier
My embedding map was working perfectly in a Squarespace website, but it has suddenly disappeared.
<head> and <body> scripts (attached are installed correctly on the website.
What can be the matter? How do I troubleshoot this disappearing map?
It should appear at this link:
https://www.keepersofthewater.ca/kow-water-monitoring-data-map
ZaraMatheson
Hi, Yes thanks for reporting. We are working on a fix that should see your original code working again soon, but in the meantime changing the script source to be https://js.arcgis.com/4.33/embeddable-components/ as suggested should fix the issue.
JonathanMcD
@BrandonGauchier
There's a few other posts on here in the last couple of days about this issue.
See my response and code;
Solved: Re: New ArcGIS Embedded map not showing (Classic i... - Esri Community
ZaraMatheson
BrandonGauchier
Thanks, @ZaraMatheson and @JonathanMcD.
