embed map viewed on mobile device
598
12-16-2024 07:34 AM
TimHayes3
Hello,
I am using the embed map HTML code from Map Viewer.
I see that the map style part of the code has a fixed height and width: <arcgis-embedded-map style="height:600px;width:700px;"
Can a ratio or percentage be provided to accommodate different screen sizes? Over 50% of the people who visit our site are on mobile.
ZaraMatheson
<html lang="en">
<head>
  <meta charset="utf-8" />
  <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no" />
  <style>
    html,
    body {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
  </style>
  <script type="module" src="https://js.arcgis.com/embeddable-components/4.31/arcgis-embeddable-components.esm.js"></script>
</head>
<arcgis-embedded-map style="height:75%;width:50%;" item-id="cf35269c59cd45cc9bfae3480c0a64d7" theme="light" portal-url="https://arcgis.com" information-enabled>
</html>
Hello! You should be able to use a % for the width or height of the embedded map as long as the body  or containter has a height/width defined. The above works for me.
TimHayes3
Thank you for the response, Zara. Will this work in an iframe? here is the code I am using:
<iframe width="1000" height="700" frameborder="0" scrolling="no" marginheight="0" marginwidth="0"
src="https://xyzxyzxyz/xyzxyzxyz/xyzxyzxyzxy"></iframe>
Where would I add the % of width and height in this code?
