Efficient alternative to setting a reference scale in ArcGIS Online
1529
11-30-2022 07:04 PM
amit_esri
Hi everyone,
I have been advised my ESRI support that it's not possible to set a map reference scale in AGOL.  The suggested workaround was to go into each Feature Class and change the Visibility Range for each zoom scale.
However, if I want the line to thin as I zoom out on each middle mouse wheel increment (and vice versa), using this method, I would need to create at least 7 copies of each FC, each with an incremental visibility range to encompass my required zoom range (highlighted below):
The screenshot below is zoomed out (around 0.5km across)
I want these line to be very thin, zoomed this far out.
Is there a more efficient method to make the lines a real-world consistent thickness?  I have ArcPro 3.x and also have access to FME.  Thanks.
amit_esri
