Editing Internal Layers
9835
15
06-03-2011 05:04 AM
by Anonymous User
Not applicable
When I point the ArcGIS Online Map Viewer at a MapService on our internal network, I get the following message:
Layer 'MyService - MyLayer'
seems to be on an internal network and is not accessible to ArcGIS.com. Thus, editing will be disabled on this layer.
Is there a technical reason why editing is disabled? Is there any way to enable editing of internal layers?
NguyenVan_Thanh
I am having the same problem but only with Internet Explorer, when I use Firefox it works fine!
Thank you very much man, you saved my days.
BrandonKeinath1
Firefox asks for my login but still show disabled editing error message after logging in.  Any updates from people on this?
KellyGerrow
Esri Alum
Hi Brandon,
Are you using an ArcGIS Server Service? If so, what kind of security is enabled on your service?
Editting an ArcGIS Server based Feature Services with Web Tier Authentication is not supported functionality in ArcGIS Online.Token based Security will allow editing through ArcGIS Online.
ArcGIS Server web services—ArcGIS Online Help | ArcGIS
If the service is a hosted feature service, please ensure that editing is turned on on the layer or in the web map.
Kelly
BrandonKeinath1
Hi Kelly,
Thank you for the information.  We do use web tier authentication but it seems like our reasons for why have changed.  I plan to switch to token and see if the issue is resolved.
Best,
Brandon
BrandonKeinath1
Hi Kelly,
I made the switch and now when I look at the service details it asks me to login.  And unfortunately none of my logins seem to work.  My guess is there are some other settings I need to change to support token based security.  Do you know of set-up documentation I could look at prior to submitting an esri ticket?  Is it in the link you provided before?
Brandon
KellyGerrow
Esri Alum
Hi Brandon,
Try this tutorial for assistance with creating secured services with built-in token security.
If you wish to store the credentials with the item, follow this documentation when adding the service.
Let me know if this helps,
Kelly
