Editing Fields in Map Viewer (not Map Viewer Classic)?
894
06-06-2024 03:07 PM
Labels (2)
KatMaloneyODEQ
Hello there,
I am wondering if there is a way to edit and add new fields to attribute tables in the "new" version of Map Viewer? I am wondering if this feature is currently available, or if I will need to continue to view my web maps in Map Viewer Classic if I want to make changes to fields? If I need to use Map Viewer Classic to edit and add fields to my features- will Map Viewer Classic be sticking around for a while?
I have been using the following instructions for editing features:
https://enterprise.arcgis.com/en/portal/latest/use/work-with-tables.htm#:~:text=If%20your%20user%20t....
Thank you!
DavidSolari
MVP Regular Contributor
If you're on 11.3 you should be able to do anything in this help topic. 11.1 (and maybe 11.2?) has limitations with editing related data so you'll need to stick to the old viewer until your org upgrades.
