Edit Widget Slow to Load
4518
14
07-02-2025 09:52 AM
VictoriaC
Real-world Problem
In search and rescue, we need the field users to be able to do basic mapping of their search areas without assistance from GIS Specialists. This means our maps often have many reference layers related to all possible disasters (flood models, hurricane forecast, earthquake Shakemap).
Technical Problem
To do this we provided the “Intel Manager” which was originally based on Web App Builder but are transitioning to Experience Builder. The Edit widget in Experience Builder leverages the Map SDK for JavaScript widget, and the issue described below can be observed across the different apps who depend on this component (Map Viewer, Experience Builder, Instant Apps).
The Editor widget is very slow to load the first time it opens (sometimes 5 seconds, sometimes 1-2 minutes!). By inspecting the error and network console, we believe this delay may be caused by the way the JS SDK loads all layers in the map, even when they are not initially visible, and that the Editor waits for all the layers to be loaded to check for the valid editable layers.
Here is our Sandbox application for testing, see the reproduction steps here: https://github.com/pjdohertygis/SARCOP/issues/450
Only a few layers are editable and have feature templates, while most of the layers in the map are for reference only to support the different editing and analysis workflows.
Possible Solutions
We’ve had recommendations from Esri in the past to hide/turn off layers in the map that are only needed by users on demand to improve loading performance. Based on the current use case, it appears this workaround is not applicable. While we are attempting to reduce the number of layers in our map, we feel the performance for loading layers in the map and the Editor widget should be optimized.
We feel there should be logical checks when loading layers in maps and apps, so that data is only loaded when necessary. Furthermore, if data cannot be loaded because it is not accessible for any reason, it should not excessively slow down or prevent the loading of the rest of the map/app.
While it seems this may need to be addressed on the JS SDK, perhaps there could be an app level check. For example, provide an option to “bypass” any layers not included in the Edit widget configuration in Experience Builder?
@PaulDoherty3 @JaredDoke @ChristopherPierson1
LindsayRaabe_FPCWA
MVP Regular Contributor
Support ticket submitted to add support to the listed Bug and Enhancement requests above!
UPDATE: Response from Esri Support (Australia) below.
The slower performance observed in the Edit widget was attributed to querying all layers within the associated Web Map. This issue aligns with a previously identified defect (ENH-000175894), which was addressed in the ArcGIS Online June update.
However, similar behaviour has been reported again in this case and a few others. As a result, a new defect has been logged to formally recognise this recurring issue with the Edit widget in Experience Builder.
ENH-000178405 - Allow the Edit widget of ArcGIS Experience Builder application to load faster.
Lindsay Raabe
GIS Officer
Forest Products Commission WA
JoseBanuelos
This has been resolved in the upcoming 4.34 release tomorrow. I double-checked with the data provided in the original post, and I no longer see the issue. Please let us know if you are still experiencing the same issue.
Thanks!
Jose
ericsamson_tract
This is still an issue as of experience builder 1.19. I will call to create another case.
It still iterates through all of the rest services to check which ones are editable, even though we have the one that is editable checked off within the experience builder settings.
JoshuaHouse
Similar behavior with Analysis Widget & GeoProcessing service.  Apples to apples comparison to simply load the widget and draw the analysis extent (not run the analysis):
WAB 2.27:     7 seconds
EXB 1.18:     60 seconds
ericsamson_tract
Still an issue almost a year later
