Edit Attribute Table ArcGIS Online
6373
06-26-2013 12:47 PM
LindseyBricklemyer1
Hi, I have a feature service with 1,000 line segments that all contain the value 0. How do I do a batch edit to change this value? I don't have time to click on each individual line segment but I want the field to be empty and not have the number 0 in it.
ThomasKonzel
I don't know if you've solved this issue, but I believe there's now a Calculate process in the feature service table.
KellyGerrow
Esri Alum
There is the ability to calculate fields in ArcGIS Online. Here is a link to the documentation that explains calculate fieds: http://doc.arcgis.com/en/arcgis-online/use-maps/work-with-fields.htm#ESRI_SECTION1_28F344E2E80C410A9...
