Dynamic Hosted Map with Features possible in ArcGIS Online?
963
11-14-2012 11:58 AM
DimitarKolev
I am trying to implement a program for automated updates on Feature Service hosted on AGO. A hosted map on AGO will display those updates. I am not sure if AGO supports that scenario.
I have a local SQL database that stores Road Statuses. I want to write a program (windows service, if possible) that will read those Road Statuses from a local database and update the Feature Service on the AGO. Then the AGO Map will change the color of a road based on its status.
So, my question is:
Is it possible to automate the scenario above utilizing AcrGIS APIs?
If yes, can you point which API I should use as a best practice.
Please share any related programming samples for ArcGIS Online, if available.
MikeMinami
Esri Notable Contributor
Check out the JavaScript API...there are many live samples you can look at.
http://help.arcgis.com/en/webapi/javascript/arcgis/help/jssamples_start.htm
Mike
