Drawing info is not applied for layer within a group layer within map
812
07-07-2025 04:52 PM
QAAccount
I have a map in the MapServer that contains a group layer as shown here. When I add it as a layer inside Map Viewer, I get a dotted line where the drawing info on my layer (lines_for-advanced_symbols_1) is not applied.
 "drawingInfo": {
  "renderer": {
   "type": "simple",
   "symbol": {
    "type": "esriSLS",
    "style": "esriSLSSolid",
    "color": [
     0,
     0,
     0,
     255
    "width": 3.4
However, when I add only the layer by itself to the map viewer, it is rendered with its drawing info and renders as a solid line.
Is this expected, why is the drawing info not used when it is added within the map?
RussRoberts
Esri Notable Contributor
Yup this is expected. When adding it as a MapServer url the rendered line is coming from the server in an exported image which can give you that dashed symbol. When you use the direct layer url like MapServer/2 it gets treated as a feature layer and the symbol can be the simplified renderer. You can use vector symbols from a web style to style the MapServer/2 case to look like the exportedImage scenario.
