When working on a hosted feature layer in ArcGIS Pro, subtype descriptions show in the attribute table but not the domain descriptions. The "Show domain and subtype descriptions" option is selected and the domains are listed on ArcGIS Online. I am using ArcGIS Pro version 2.4.1. The layer was first created in Pro using the lat/long coordinates in an Excel file and then shared as a web layer. The domains and subtypes were established in Pro before sharing. Did I miss an important step when sharing the layer or accessing it in Pro?
Hi Ming,
Do you have a screenshot of this issue?
Marisa
Hi Marisa,
This is the feature class with a subtype for the Site Type field and domains for the subsequent fields. I published this to AGOL.
When I open the hosted feature layer in Pro, the attribute table looks like this. Only the subtype descriptions display. The other fields display as their codes and do not have the drop-down options.
The subtype and domain descriptions do show in AGOL.
The domain descriptions show only when I publish the feature class without a subtype.
Thank you for your help.
Ming
Hi Marisa,
Were you able to look at what is causing this to happen? Thank you.
Ming
