Does ExperienceBuilder allow users to print/save chart images?
521
01-06-2026 09:04 AM
wnh
I have built a webapp through ExperienceBuilder which has a map and various chart widgets that update as you select records. Is it possible for users to save these graphics via a widget? I have used the print widget in the past, which seems to be exclusively compatible with the map widget for exporting a layout.
VenkataKondepati
Honored Contributor
The Print Widget only handles the Map, while the Chart Widget has its own built-in export tool. You just need to go into each Chart’s settings and toggle on the Export option under the Tools tab, which lets users save the graphics as a PNG, JPEG, or PDF.
Regards,
Venkat
Follow me on: LinkedIn
If this response helps or is the solution to your post, please consider marking it as a solution
NicoleJohnson
MVP
@wnh, unfortunately the chart widget doesn't have its own printing/export chart image capability. I also just double-checked in case I had missed this from the last update or something, but no, it just doesn't exist.
If it's a feature you really want, check if anyone has added it to the Experience Builder Ideas board. It's something I've also been asked about, so I would definitely give it a kudo if you made a post.
