Does Arcade support multi-dimentional arrays?
1556
04-03-2024 11:19 AM
SteveCole
Honored Contributor
I have some pop up logic written in for the Javascript API but I want to port that over to AGOL/Portal Web Map popups but my content logic revolves around the use of multi-dimensional arrays. I don't see anything explicitly stated in the documentation hence this post.
The context for this is that I have a census data layer which has 150 attribute fields with count values. For each non-zero value, it is added to a multi-dimensional array where the 1st column is a label, the second is the percentage based on a total population subset, and the third column in the array is the percentage based on the entire population of the census tract.
Once the array is fully populated, I sort the array in descending value order based on the 2nd column of the array and then build out an HTML table for the pop up. Anyways, I can do this in the JS API because it's pure JS but I'm not sure about Arcade.
Thanks!
SteveCole
Honored Contributor
In answer to my own question, the answer appears to be yes, they are supported. A simple test case:
Not sure about sorting it but I guess that's the next thing to tackle..
SteveCole
Honored Contributor
SteveCole
Honored Contributor
To follow up myself once again, you can sort the multi-dimensional array inside Arcade as well. The sort function below will sort in ascending order:
var a = [];
push(a,['Bahamas',22.5,5.78]);
push(a,['Cuba',10.2,2.9]);
push(a,['Argentina',4.6,1.1]);
function SortDesc(a,b){
  if (a[1]<b[1])
    return -1;
  if (a[1]>b[1])
    return 1;
  return 0;
var aSort = Sort(a,SortDesc);
Console(a[0]);
Console('The first column is: ' + a[0][0]);
Console('The second column is: ' + a[0][1]);
Console('The third column is: ' + a[0][2]);
Console(aSort[0]);
Console(aSort[1]);
Console(aSort[2]);
for(var index in aSort){
  Console(aSort[index][0]);
If you want descending order like I did, you simply reverse the order of the returned value in the function like this:
  if (a[1]<b[1])
    return 1;
  if (a[1]>b[1])
    return -1;
  return 0;
Although you reference array[][] using the double brackets in most parts of the code, the function only needs one set of brackets for the column. Happy hackling!..
