Does a definition query effect the hosted feature layer performance?
2065
02-24-2021 01:19 PM
JoeSaltenberger
If I have a layer in ArcMap/Pro with a definition query applied to it and I publish as a hosted feature service, will that hosted feature service perform as well compared to if I exported the subset to another feature class and published?
Even though the definition query is still applied in the hosted feature service, all the data is uploaded to AGOL, which I was thinking may have an impact on the speed that the service can process and return results from query or edit operations.
Thanks.
JayantaPoddar
One can expect the subset layer to render/query faster than the layer with definition query (the difference could be negligible for smaller datasets), just for the fact that the latter has to run the definition query on-the-fly.
But again, it depends on your requirement. You must have a reason to go with a definition-queried layer.
Think Location
