Display Features in Citizen Reporter
1199
01-14-2020 02:32 PM
JaredPilbeam2
MVP Alum
It's probably a simple fix, but I how do I get the submitted problem reports to show up on the App?
Here's what I mean; you see all features in the map here:
But, i can't find the setting to have them appear in my map(s)? I have at least 20 features (submitted problem reports) that should be in this map.
by Anonymous User
Not applicable
Hi Jared,
I noticed that you had logged a support case for this and gotten to the bottom of the issue. I wanted to cross post the resolution here in case any other folks come across this thread with a similar question: The resolution to the issue was to remove the filter set on the layer in the web map, and also as a troubleshooting step configure the application to use items shared to a different group, then back to the original group.
-Peter
by Anonymous User
Not applicable
Hi Jared,
-Peter
