Display a map from a Field containing multiple values separated by comma.
417
07-29-2024 06:08 AM
EmersonCardenasSachica
Hi, I have a map with a feature layer and a table (linked CSV)
The feature layer contain coded rooms and categories, example:
201     investigation
202     services
205A    bathroom
, etc
And the table (linked CSV) contain a field with comma separated values for spaces associated to each Lab, example
Lab:  1
rooms: 201,203,206,205A,
Lab: 2
rooms: 202,204,205, 205A, 207
this table update frequently.
I want to make a dashboard that select laboratories and see their respective rooms in a map calling from this comma separated field..as the Table is linked and change pemanently so i dont want to use geoprocessing or analyrticis .. its possible? how? thanks for your help.
ChristopherCounsell
MVP Frequent Contributor
Working this way is possible with 'contains' and filters
https://doc.arcgis.com/en/dashboards/latest/get-started/filter-data.htm
However you need to a fully unique string values. If you have a room '205' and another '205A', any filters looking for 205 in the string would pick up both 205, 205A, and all other combinations e.g. 1205, 2055...
You fix this by making a full unique string e.g. 00205, 0205A, 01205, 02055
