Deleted view layer will not go away
1061
06-17-2025 10:56 AM
esriuser12345
Hi
I deleted all view layers from my content that were listed under views on my hosted feature layer. However when I open the rest service for the layer, it still says I cannot change the source schema and the view is still attached. I don't understand why it won't go away. When I ran a code to see if I could delete it from the backend it says no views were found but, it still shows up on the rest page.
JillianStanford
Is it still in your recycle bin?
Unless you delete it permanently, it will still show up for 14 days.
esriuser12345
Yeah, i deleted it permanently from recycling bin too. still showing up
George_Thompson
Esri Notable Contributor
I would recommend reaching out to technical support on this.
--- George T.
NatC42
I am having the same issue. Were you able to resolve the issue and remove the ghosts of View Layers only listed in the Service Definition but not on the AGOL Item page, or Recycle Bin?
Thanks for any information on this issue!
