Data not Updating in AGOL Join View Feature Layer
1996
04-04-2020 11:53 AM
ChristopherEby2
I have a join view that I have created between two of my hosted feature services. It works well and I can see in the data tab of the view that the data in the view changes when the data in the services changes. However, I have added this view to a web map and the data displaying in the map is out of sync with the view. This is my join view:
https://arcgis.com/home/item.html?id=98eb52d8e8594bef8ff7a1dfd7e2c7e8
This is my web map:
https://arcgis.com/home/item.html?id=77eb3f2f36bd4d3885a3c23963ffd2e1
The example I am looking at is Monroe county where I see in my popup and on labels that it says there are 236 active cases:
In my view (and even in the table for the layer on the map) I can see that there are 484 active cases, which is correct:
Is this some kind of bug?
HassanMahmoud1
Try to save the Layer in the webmap
NourSalam
I have the same problem. I tried saving the layer in the webmap and nothing changed. Is there a resolution on this?
