DATA ERROR on AGOL DATA Table
1322
05-27-2024 06:34 AM
AdedoyinAjeyomi
I have gdb with different layers when ever I try to edit some of the rows on AGOL table view it shows a data error, but within the same table id I edit some, and it works perfectly, the issue now is this DATA ERROR is affecting my Experience builder application because all the features that show data error cannot be updated with the edit widget, but the one that can be updated on the data view can also be updated there, but all this attributes can be updated on ArcGPRO and also on web app builder, but it cannot be updated on the table view and experience builder, this is meant to be an application that will be used by public so I need my experience builder to work
David_Miller
When you shared your map from AG Pro, there is a dropdown that asks you if you want to share as an exploratory map, editable map, or a visualization. This will be found in the select a configuration dropdown.
I hope this helps,,,,,
David
