Custom Attribute Display
3594
09-07-2012 07:04 AM
EricStarn2
I am using a custom attribute display for my popup window and have some fields that are suppose to be formatted in percent.
Currently they are in decimal form.
Is there a way to format them this way in the popup config or is this something that needs to be fixed in the published service?
Eric
MikeMinami
Esri Notable Contributor
The data would need to be in the proper format in the service. There is no ability to format the fields in the popup.
Mike
MikeMinami
Mike
EricStarn2
Hey Mike,
I have another question pertaining to fields (symbolization)
I am using the color feature to class my data points however am wondering if you are able to put in custom break points like in desktop or if you can only use the ones provided? (Natural Break, Equal Interval, etc)
Eric
MikeMinami
There is no ability for custom break points.
Mike
SisiYan
It seems that even if you set the fields format to display as percentage or scientific inside arcmap pre publishing, the service still shows up as decimal. And it is only up to 6 decimal points.
