Creating popups for stacked features in the same layer
489
04-30-2026 11:41 AM
WorcesterGTSS
I have an address point layer that includes many points that are stacked (i.e., they have the same x,y location). I'm interested in creating a single popup for each location that includes attributes from all of the points at that particular location. (So, for example, if a specific location has 5 stacked points, there would one popup for that location with information about each of the 5 points.) I was wondering if this was possible, and if so, if anyone has suggestions on the best approach to do this. I have seen some posts about pulling data from multiple layers but not features from the same layer which is what I'm trying to do here.
NicoleJohnson
MVP
Assuming you have some kind of unique ID for the location, I'd make a view using "group by" (this thread goes a little further than that, but you'll get the idea: https://community.esri.com/t5/arcgis-online-documents/display-latest-feature-in-a-feature-service/ta...). Then, put that new view in your map and use Arcade to grab the features that match the ID (let me know if you need some more direction here).
WorcesterGTSS
I think this could definitely work for what I need and will give it a try - thank you!
