Create a feature layer from a WMS server/layer package
7436
06-28-2021 10:41 AM
Bryan_Wade
I created a layer in ArcGis Pro from a WMS server. I would like to take the layer and display it on a map in ArcGIS online. I saved the the layer in ArcGis Pro as a package layer, but this only allows me to share the layer if people are going to open it in Pro. I would like to display the data in the package layer in ArcGis Online so that we can run analysis with corresponding data during emergency events. Is there a way to do this?
JayantaPoddar
If you are the administrator of your AGOL organization,
navigate to Organization > Settings > Security > Trusted Servers. Add the WMS Server.
Once you've added the server to the list of trusted servers, you can add your OGC services to Map Viewer Classic or as an item. If authentication is necessary, users adding or viewing secured OGC layers will be prompted to enter their credentials.
OGC WFS, WMS, and WMTS services secured with token-based authentication are not supported.
Secure OGC Services - ArcGIS Online
Think Location
JayantaPoddar
You could add the WMS Layer(s) to ArcGIS Online directly.
From Content
Alternatively, you may add the WMS Layer(s) directly to Map Viewer of ArcGIS Online.
Think Location
Bryan_Wade
I tried that before I went the ArcGis Pro route. I just get an error message that says "Service '' does not exist or is inaccessible."
JayantaPoddar
Could you share the URL link of the WMS layer(s)?
Is it a secured service (credentials required)?
Think Location
Bryan_Wade
I can't share the link since it is a secured service that requires credentials to access.
JayantaPoddar
Think Location
