Counting Records From A Hosted Service Using Power Automate?
529
11-05-2025 05:56 AM
DaveK
Hello!
I'm trying to create a Power Automate flow which would count the records in a feature service and email that count on a daily basis. I've created basic PA flows before, but I can't figure out where to start with this one or which AGO connector to use to pull the data. The docs for these connectors is so minimal. Any help with this would be appreciated.
Thanks!
CalvinHarmin
MVP
If there's not a quick answer on using an ArcGIS connector for this, here's how you can do it via an HTTP action instead:
Overview/proof of concept:
HTTP action to get AGOL token with REST API
Query hosted feature layer HTTP action using REST API
Note: the URL for the hosted feature layer needs to include the /0 or whatever the sub-layer index number is.
