Correct arcade label in AGOL based on if, else if and else
1731
01-19-2021 12:05 AM
PeterGill2
I am trying to create an arcade expression for my labels in the map
The following is the expression I have done - but on the second line - when I test - it says if  "assignments not be made in logical tests"
if (!IsEmpty($feature.OPERATIONALID)) {$feature.ASSETID}
else if ($feature.OPERATIONALID = $feature.ASSETID) {$feature.ASSETID}
else {$feature.ASSETID + " (" + $feature.OPERATIONALID + ")"}
What am I doing wrong.
Basic logic is:
If OperationalID is null or empty then label assetID, if operationalID = AssetID, label AssetID, else label a concatenation of assetID + OperationalID
DavidPike
MVP Notable Contributor
I've only a basic javascript knowledge, but it seems like you have a rogue "!" before isEmpty(),
and $feature.OPERATIONALID = $feature.ASSETID is an attempted assignment without a 'var' etc. I'd say it should be a comparison operator "==" $feature.OPERATIONALID == $feature.ASSETID.
if (IsEmpty($feature.OPERATIONALID)) {$feature.ASSETID}
else if ($feature.OPERATIONALID == $feature.ASSETID) {$feature.ASSETID}
DavidPike
PeterGill2
Thanks David - works perfectly
