Conditional field showing using arcade in map viewer popups
2964
06-01-2022 09:41 AM
SRanseen
Hi all
I am new to arcade and have mostly only used it in field map forms and labels.
I need to hide a field in the pop up based on the attributes of a separate field.
The project is our adopt a street program. The user wants the link to adopt a street hidden if the street is already adopted or pending adoption.  They also want the adopted group name field to be hidden if the street is available.   I saw methods to hide a field based on conditions related to the same field but I did not find a method to hide a separate field based on another fields attributes.
Link to web app we are using the web app to embed the map in the adopt a street website.
What I am looking for:
If ($feature, "street_adoption_status") != "Available"  than $feature["Link_Txt"] is not visible in pop up
If ($feature, "street_adoption_status") == "Adopted" than $feature["group_name"] is visible in pop-up
Any help is appreciated.  Thank you for your time.
JohannesLindner
This isn't possible in the default fields element.
There's (at least) 2 options:
  • write custom HTML in a text element (switch to HTML source) or an Arcade element, using the display style attribute to control whether you want to show a value or not:
<table>
<tr><td>Street</td><td>{street_map}</td></tr>
<tr style="display:{expression/expr0};"><td>Group></td><td>{group_name}</td></tr>
</table>
// expr0
// style="display: block;" shows the element
// style="display: none;" hides the element
if($feature.street_adoption_status == "Adopted") { return "block" }
return "none"
  • define your fields in an Arcade element:
var trash_val = `${$feature.Total_Trasj} lb`
if(trash_val == " lb") {
    trash_val = null
var field_values = {
    "Street": $feature.street_map,
    "Street Adoption Status": $feature.street_adoption_status,
    "Street Length": `${Round($feature.Miles, 2)} miles`,
    "Total Trash": trash_val,
    "Adopt-A-Street Application": $feature.Link_Txt,
    "Adoption Group": $feature.group_name
var fields = [
    {"fieldName": "Street"},
    {"fieldName": "Street Adoption Status"},
    {"fieldName": "Street Length"},
    {"fieldName": "Total Trash"},
if($feature.street_adoption_status == "Available") {
    Push(fields, {"fieldName": "Adopt-A-Street Application"})
    Push(fields, {"fieldName": "Adoption Group"})
return {
    type: 'fields',
    "fieldInfos": fields,
    "attributes" : field_values
Have a great day!
Johannes
JohannesLindner
<table>
</table>
// expr0
return "none"
    trash_val = null
var fields = [
return {
    type: 'fields',
Have a great day!
Johannes
SRanseen
Thank you.  I would not have figured that out with my current Arcade coding knowledge.
LukeAllen2
Hi Johannes,
The HTML opposite (First) to hide the fields from showing in the pop-up is this HTML code for the latest Map Viewer or for Map Viewer classic (or both?)
Thanks!
JohannesLindner
I know it works with Map Viewer Classic, but it should also work with the new Map Viewer.
Have a great day!
Johannes
