Cluster on custom base map
1977
04-08-2019 02:24 PM
by Anonymous User
Not applicable
Hello,
I am trying to use a custom basemap (more updated) rather than the esri one. The problem is that when i use my custom bsaemap I lose the cluster. And even the cluster button disappear in Arcgis online (see attachment).
Any idea about how to solve the issue?
KellyGerrow
Esri Alum
Hello,
There are some considerations to review when using clusters: https://doc.arcgis.com/en/arcgis-online/create-maps/configure-clustering.htm#ESRI_SECTION1_8D5C42DBE...
I expect that this is the limitation that you are running into if your basemap is not in WGS84 or Web Mercator
  • To configure clustering on a point layer, the map must be in the WGS 84 or Web Mercator coordinate system.
-Kelly
KellyGerrow
Esri Alum
Hello,
-Kelly
by Anonymous User
Not applicable
Thank you that solved my problem
