Changing field name in Interactive Legend App
3866
04-12-2019 10:55 AM
EvanStern
The screenshot I have attached explains it best. The text highlighted in blue next to my cursor is the text I would like to change. I was able to do it once before, but I can't remember how. Is there a way to do this without going all the way back to my map in Arc desktop to change it?
Evan
KellyGerrow
Esri Alum
Hi Evan,
This can be changed. Here is a sample App that I made from your web map:
https://webapps.maps.arcgis.com/apps/InteractiveLegend/index.html?appid=4d398647b09245c589fe66f41d00...
You'll notice that in my app there is the word Vegetation instead of VEG_NAME.
What I did was updated the field alias in the pop up. You can also do this on the data tab of the layer so that the field alias' are human readable.  Just make sure you save the field alias' to either the map or the layer.
Let me know if that gets you up and running.
-Kelly
KellyGerrow
Esri Alum
HI Evan,
You can change this by updating the layer name and saving it in the web map or on the layer item:
https://doc.arcgis.com/en/arcgis-online/manage-data/item-details.htm#ESRI_SECTION2_C1378B44CC614A80B...
https://doc.arcgis.com/en/arcgis-online/create-maps/organize-layers.htm
Feel free to share your web ma if this doesn't resolve the issue.
-Kelly
EvanStern
Kelly,
I'm not sure those were quite the right thing. Here is the map: http://thewilds.maps.arcgis.com/home/webmap/viewer.html?webmap=f05be8d1c6b9429287ad0a40ae1a0caa
"VEG_NAME" is the name of the attribute field in which the cover type names are under. Can this be changed in ArcOnline?
Thanks!
Evan
KellyGerrow
Esri Alum
Hi Evan,
-Kelly
EvanStern
Kelly,
Perfect, up and running. Thanks!
Evan
