Caution message while constructing a map in ArcGIS online
1397
12-15-2011 06:24 AM
DanaKahle
Is this a problem for anyone else ? See attachment...
MikeMinami
Esri Notable Contributor
This is a problem you'll see with Internet Explorer when your web map starts to get big, like when you have added a lot of layers to the map (e.g., shapefiles). Layers that are stored in the map rely on the browser to draw them. IE doesn't have the same capabilities as Firefox and Chrome, so you'll start to see these errors. If you can, I'd suggest switching browsers. If you can't switch browsers, you might try installing Chrome Frame, which effectively runs Google Chrome inside IE.
Mike
DanaKahle
Mike
Thanks Mike. I am going the Firefox route !
