Cannot get pop-ups to work
2813
11
10-24-2011 06:58 PM
JustinCure
I have been trying unsuccessfully to implement pop-ups on my webmap.  I have configured them and shared the map to everyone.  Help!
http://www.arcgis.com/home/webmap/viewer.html?webmap=e9cb1cfc69bd4af9bf1f84cbdba47f03
MikeMinami
Esri Notable Contributor
I recall we have a problem with 9.3 ArcGIS Servers. Try setting the scale dependency on each layer, not on a group layer. This should solve your problem.
Mike
JustinCure
It didn't seem to fix it.  Any other ideas?  Thanks!
MikeMinami
Did you also remove all scale settings from the group layers?
Mike
JustinCure
Yes, I removed the scale dependencies on all group layers.
MikeMinami
We're having trouble accessing your server right now. It could be down. Queries against the particular service don't seem to work. How is your service configured? Have you enabled security on it?
Mike
JustinCure
Yes, our server was having issues late last week.  Those have been resolved.  I also removed all group layers to see if this would fix the issue.  It has not.  The service is configured on ArcGIS Server 9.3 as a pooled map service.  No security exists except for a firewall.  The updated path is http://www.arcgis.com/home/webmap/viewer.html?webmap=fa9b8cf1c58142da93d52f68b74850c4
J
MikeMinami
The queries ArcGIS.com sends to your server are failing. I did a little more investigating and found this forum post that discusses the particular error I'm seeing ("Unable to perform query.  Please check your parameters").
http://forums.esri.com/Thread.asp?c=158&f=2399&t=263435#810143
There is a reference to SP1 having a fix for the problem. Based on the date of the forum posts, that would appear to be 9.3 SP1. You can find the download here.
http://resources.arcgis.com/content/patches-and-service-packs?fa=listPatches&PID=66
In short, you need to upgrade your ArcGIS Server in order for the popups to work in ArcGIS.com.
Mike
JustinCure
Excellent, upgrading ArcGIS Server got the pop-ups to work on ArcGIS.com.  I try using the map on an iPad and it crashes the ArcGIS app.  Any ideas?
MikeMinami
We'll have to take a look. Can you share the URL to your map? Also, are you running the ipad application or just using the Safari browser? I think you're using the app. You might try simply using the browser too...
Mike
