Cannot add WMTS service to map
8066
04-18-2014 06:07 AM
DonBarker
We have the option to Add Layer from Web > Add WMTS OGC Service.
This is the URL that I add, which fails:
http://choptankriverheritage.org/tileserver/1875bw/wmts
The error message from AGOL:
"The WMTS service, http://choptankriverheritage.org/tileserver/1875bw/wmts, can't be added to the map. It's either not available or you have entered an invalid URL for the type of layer you want to reference."
This describes the WMTS:
http://choptankriverheritage.org/tileserver/1875bw/WMTSCapabilities.xml
This WMTS is generated by Tileserver by Klokantech ( github.com/klokantech/tileserver-php/ ).  It claims to be compliant with OGC Web Map Tile Service (WMTS) Both KVP and RESTful version 1.0.0.
Can anyone help?
DonBarker
A note for anyone using Klokantech's Tileserver -- You'll need to configure the tileserver.php file from localhost to your domain and the Tileserver folder, like this example:
Change this
"baseUrls" => array("http://localhost/")
to this
"baseUrls" => array("http://choptankriverheritage.org/historic_maps/")
This fixed the error that prevented me from adding the WMTS to my AGOL map here:
https://www.arcgis.com/home/webmap/viewer.html?webmap=1900ca75fa504ab9a831351a54c17dcb
Thanks to Chris for pointing this out.
DonBarker
I just discovered part of my problem.
I was using the URL for a single WMTS layer.  This is the correct URL for the WMTS server:
http://choptankriverheritage.org/tileserver/wmts
It gets the WMTS capabilities (layer list) correctly and sends layers to my map here:
It reads the extent correctly, too.  But the layers still are invisible.
Any ideas?
Don
ChrisWhitmore
Hi Don,
For completeness sake, here's the response I sent you over email:
Looks like there�??s an issue with the capabilities xml for the WMTS�?? it has references to localhost:
http://choptankriverheritage.org/tileserver/wmts/1.0.0/WMTSCapabilities.xml
Get xlink:href="http://localhost/wmts?">
Changing localhost to your WTMS server name should resolve the issue.
Chris
DonBarker
Chris,
Thanks for looking into this.
At about the same time as your email, I got one from the developer, who noted a bug in their server app that created this localhost reference problem.  (Naming the server folder 'tileserver' -- same as the app name -- causes naming collision).
I'll be working this later today.  Appreciate your help.
Don
DonBarker
Change this
to this
