We have successfully set up a test set of our users to connect to ArcGIS Online using the same credentials they use to access other enterprise applications through active directory federation services. In order to support some of our use cases we'd like to add users from another federation service, is this possible?
Heather
Hi Heather,
You can configure a single SAML provider to a single ArcGIS Online organization, configuring multiple providers isn't possible currently.
Can you submit this as an idea on the ideas site?
Kelly
Hi Heather,
Kelly
