Can a Story Map use an Interactive Legend?
2287
11-17-2020 12:58 PM
UnderstandFast
I'm exploring Esri's pre-made web app templates, and the Interactive Legend looks very helpful. When I create a Story Map, I don't see a way to have the maps within it have an Interactive Legend. I'm wondering if it is possible to do this.
ManishPatel
Hi @UnderstandFast
Yes, you can use it in your Storymap, once you have the web app, copy and add the URL using embed option.
Upon saving you should be able to view the web app in the StoryMap. Please check this link as an example
https://arcg.is/1SfCbP
Cheers,
Manish
If this answer solved your question or if you found it helpful please mark it accordingly to help others who have the same question.
Cheers,
Manish
ManishPatel
Hi @UnderstandFast
Cheers,
Manish
Cheers,
Manish
UnderstandFast
Thanks, @ManishPatel. Creating a web app (or apps) with the Interactive Legend, then adding those apps to the Story Map is a reasonable workaround.
I was thinking specifically of the Story Map "Series" where you can have each tab's location be inherited from the first map; I think the embed method won't do this.  Still, what you suggest is a good workaround - thank you.
Hopefully Esri adds a widget for an interactive legend to story maps!
