Calculated Expression with Feature Set in Web Map
1739
11-02-2022 05:36 AM
jtmouw_NCDOT
Is there a timeline for Feature Sets to be supported in AGOL Web Map Viewer's smart forms? It is frustrating to be able to Auto-Populate fields in Field Maps spatially (such as auto-populating the a "County" field when a user drops a point, based on a County layer in the map) but to be unable to do that in a web map.
We are hoping to give in-office/non-mobile users access to a web map and spatially/automatically derive a number of fields that there is no reason they should have to fill out, but while the functionality works in Field Maps, I see the below warning in the new Web Map Viewer:
Expression compatibility
Calculated expressions that use Feature Sets are not supported in Map Viewer.
So I was wondering  when this might make it over to the AGOL side, or alternatively if there is a way to open a Field Maps map on desktop, so that we can use the Feature Set capabilities?
EmilyGeo
Hi @jtmouw_NCDOT
As of the November 2022 update Feature sets are now supported in Map Viewer. There is more information contained in this article on the ArcGIS Blog site.
gargarcia
The experience builder edit widget is can be set to populate based on the field map form so I think it may honor those kinds of field calculations
delainebegley
Thank you. All is clear.
mapquest directions
EmilyGeo
Hi @jtmouw_NCDOT
