calculate density failed
1829
05-21-2019 03:35 PM
AllenRisley
I have point data that is being collected using Survey123 and I would like to use the Calculate Density analysis tool to get a density plot of the points.  I'm using the defaults and have my map zoomed so that the data I am interested in is displaying on the map.  Every time I run the Calculate Density tool in ArcGIS Online  it churns for a few minutes and then throws up an error message: "CalculateDensity failed".
Has anyone else ever seen this error before?  Any ideas what is causing the problem?
Thanks in advance,
AllenRisley
It turns out the problem was that the feature layer I was trying to run Density Analysis on was a view layer.
AllenRisley
