bulk geocode service
2214
05-28-2024 03:41 PM
JayLarsen
I have to geocode about 500k addresses (all in AZ USA).
That should be around 20k credits.  Which is about $2400 worth of credits.
I thought there used to be an ESRI "bulk geocoding" service that was cheaper or something?
Is there a cheaper way to do this? That's a year's worth of AGOL subscription in credits alone...there must be a cheaper way?
Tags (3)
MichaelVolz
Esteemed Contributor
There is a free Census based geocode service, but it would need to be broken up into batches (Not sure it is worth it with that many records)
JayLarsen
Oh yeah? What's the URL?
Must be this one?
https://help.bdc.fcc.gov/hc/en-us/articles/5341095744283-How-to-Use-the-Census-Geocoder
Thanks!  Makes me think googling around a bit might turn something up...
ConstantinePapadakis
I have used the Google Reverse Geocode API with success.  You would use the Google Geocode API. Google has  tool to estimate your costs.  I I built a Excel Workbook template with a starter cell of some xml conversion language that includes the google api. I drop a table of coordinates from Pro to the workbook which auto converts the data.  Works well.  Let me know if you want the step by step youtube tutorial I followed.
Also, you might try getting some quotes from vendors/ list aggregator type companies.
JayLarsen
Thanks.  I checked the costs, and they're basically the same as ESRI, but with more data prep.
I'm a bit shocked there wasn't a cheaper solution anywhere that was attractive.
