Bulk Editing Deleting Fields
113
yesterday
WMANDD
We use the Bulk Edit feature quite often for our maps. Today we came across something that seemed to have changed. When we bulk edit a group of objects that have different values for a field, the bulk editor immediately selects the first data box without user input. The issue that comes of this is it deletes ALL the values in that field for all the objects even if we click away or tab away. This was not an issue a week or so ago.
Is this from a recent change or a bug? Is there a way to avoid the data instantly being wiped out when Bulk editing?
JonM32
@WMANDD
It's likely a bug if it wasn't an issue a weekish ago.
Esri's June Update doesn't have a good track record, if I had to guess it's related to that. See the thread below for known issues so far.
Re: ArcGIS Online June 2026 Update – Known Issues ... - Esri Community
Cheers,
Jon
If this response helps or is the solution to your post, please consider marking it as a solution
CraigGillgrass
@WMANDD I can reproduce this issue, we'll starting looking at it asap.
Have you reported this to Support yet?  If so, can you let me know what the incident number is.
WMANDD
I have not reported to support. Actually not even sure how i would do that.
CraigGillgrass
that's ok @WMANDD we're working on a fix for this. The fix should be available tomorrow or Wednesday.
