Blacked out map in MapViewer
3308
6
04-24-2023 02:01 PM
cweirpatrickco
Howdy folks,
I'm running into an issue that I've never seen before. I shared two feature classes to a group layer from Pro to AGOL with no issues. When I try to view the group feature layer in MapViewer, I get this black void in the map frame (see screenshot).
What's going on here?
TIA!
Woodpecker
Hard to know from this screenshot. Did the layers load correctly? If you click on layers, are they included in the layer list? If so, what happen if you zoom to the layer?
Do you have a basemap selected?
I've never had this issue, but clearing the browser cache often helps with unexpected behaviour.
cweirpatrickco
Interesting, I just tried opening the map in chrome and it worked fine. I was using Firefox before.
RussRoberts
Esri Notable Contributor
This hasn't come through any of the channels I track.. can you share the web map and I can take a look?
Thanks!
Ade_Bruijn
Unfortunately, I'm suddenly getting a black map in FireFox, Chrome is fine, but Edge is also having problems. EB works fine, but loading the webmap results in a blank screen. Clearing the cache and restarting FF didn't solve the problem. Hopefully rebooting the PC will fix it, all the maps I try stay black. Also tried maps from various organisations
Boomspiegels (arcgis.com)
https://www.arcgis.com/apps/mapviewer/index.html?webmap=873e7ca1457a4724b162c42bbf0ff97c
Ade_Bruijn
Update: Rebooting the PC solved the problem
matt_g_g
Did anyone ever find a resolution/cause for this? I get this intermittently from Firefox. It was originally with Enterprise 10.8.1 but has recurred with Enterprise 11.3.
