Bing Base Map Projection Error
884
02-26-2013 05:39 AM
BeckyHjelm
Please view this map. http://bit.ly/15Nddz8 . When you zoom into the basemap at the largest scales it appears to have a projection issue with the operation data. They operation service is in UTMNAD83 Zone 12N. I noticed this once I switched my basemap options to our own custom BMs that are also UTMNAD83 Z12.
BeckyHjelm
I actually just noticed that the shift only happens when the map item is launches from our Home Page or when it is embedded into another webpage. The share link must accommodate the projection somehow.
Please view it from uplan.maps.arcgis.com and click on Utah Unified Transportation Plan Map 2011-2040 from the featured content bar and zoom in.
Also see it here http://www.udot.utah.gov/main/f?p=100:pg::::1:T,V:207
by Anonymous User
Not applicable
Hi Frank,
I see that when I click on the view in larger map, it zooms to africa. It looks like the extent parameter that's being passed in is off. I think if you remove it from line 266 in your code, it will work as expected and open to the extent of the webmap like this.
http://uplan.maps.arcgis.com/home/webmap/viewer.html?webmap=8736efcfd16745428a4335931acf672c
Andrew
