best practices
2202
07-17-2013 06:29 AM
JacobBoyle
I have a few questions as we prepare to deploy Portal when 10.2 comes out.
[INDENT]
  1. What is the best practice for deployment, in regards to server resources?  Would it be better to deploy Portal on a separate server from ArcGIS for Server?
  2. If it should be deployed on a separate server, what are the recommended hardware requirements, are they the same as ArcGIS for Server?
  3. Is there any documentation available online to help with deployment?
[/INDENT]
TatianaRestrepo1
DerekLaw
Esri Esteemed Contributor
Hi Jacob,
I think it depends on the load and capacity that your Server and Portal sites will be supporting.
As Tatiana referenced in her post, the Portal system requirements are in the help documentation.
The ArcGIS Server system requirements can be found here.
Portal for ArcGIS general help
Portal for ArcGIS Administrators guide
Hope this helps,
JacobBoyle
Thanks for the help!
