Batch Export of rows in attribute Table
1998
01-20-2023 07:10 AM
TimothyODoherty
I am working in ModelBuilder and having trouble exporting the data into individual features.
I have an attribute table with >500,000 polyliones, I have the grouped the polylines into ~250 groups and want to export each group as their own feature. My plan was to use the 'select layer by attribute' tool but how would I batch run this to export all features in one simple tool?
RhettZufelt
MVP Notable Contributor
Sounds like the Split by Attributes tool.
R_
TimothyODoherty
Yes, I understand that Rhett. But what I am struggling with would be how to I run a 'Select by Attribute Tool' for each unique value in my field?
RhettZufelt
I don't mess with models much, but suspect an interator would work here.
I'd use python and:
create an empty list
use search cursor to populate the list with all the values of the field
turn that list into a set (so is uniuqe without duplicates)
iterate through the list and pass that to the Select By Attributes
export.
fc = r'Database Connections\pathtofeatureclass'
search_field = 'AttField'
AttList = []
with arcpy.da.SearchCursor(fc, [search_field]) as cursor:
    for row in cursor:
       AttList.append(row[0])
AttSet = set(AttList)
for att in AttSet:
    where = f"{search_field} = '{att}'"
    arcpy.management.SelectLayerByAttribute(fc, "NEW_SELECTION", where)
    ## Export or other stuff
Should work if running in Pro with fc loaded.  If not, will probably have to make feature layer first as the SelectByAttributes needs a view/layer not a feature class.  If so, could skip the SelectByAttributes and just pass the same where clause to the MakeFeatureLayer GP tool, then export the feature layer.
R_
