Using the Batch Attribute Editor in a Web App, Can you use the select by point option in conjunction with holding down a keyboard key to specifically select certain features? The batch attribute editor freehand polygon tool works in this manner, but it's a bit cumbersome. Looking to select features for batch attribute editing like adding to the selection or like the selection button works in conjunction with the shift key in ArcMap. In a Web App, the Select Widget using the Select By Circle options works this way, but then you don't have the option to edit, let alone batch edit.
