Basemaps shift and move when zooming in and out, misplacing features.
2204
08-23-2023 09:53 AM
CaseyPrice
When zooming in and out on ArcGIS Online, the basemap (no matter which one) will shift around. The features stay in place, meaning that zooming in can make a feature appear to have moved a considerable distance.
Take a look at the video. After placing a feature on the intersection of a road and then zooming in and out, the basemap shifts around, completely misplacing the point feature. In the video I show this happening with both the Imagery basemap and the Topographic basemap.
How can this be fixed? Thanks.
CaseyPrice
New information: This is only happening on the newer Map Viewer. Upon switching to Map Viewer Classic, the basemaps stay put. Weird!
David_McRitchie
Hey Casey,
This is rather odd behavior. Since this is only happening on Map Viewer I think it would be best if you raised a Technical Support case with your distributor as this looks like a defect.
It would also be worth confirming if this is happening on all base maps, and within different locations.
Hope that helps,
David
Esri UK -Technical Support Analyst
ElieRizk2
I am facing the same with the web map shared using ArcGIS Pro, I attached a video showing two maps:
1. the first map doesn't have this issue, where I am using the event theme layer reading from a view with unique value symbology.
2. the second map has the same data source with one difference being that I am using heat map symbology.
when zooming out to infinite zoom the heat map goes out of its initial extent as shown in the attached video.
I am not able to sort out the behavior behind that noting that I am using ArcGIS Enterprise 11.2 and Pro 3.2
