Attribute Is Type String In Attribute Table But Displays in Popup As Float
2200
01-10-2024 05:34 PM
GregReinecke
Hello,
In AGOL Mapviewer I have displayed my point feature map. For the selected point feature the zipcode (ShippingZI) is in string format in the attribute table as "02453", in the Fields list it's a string "abc" type, I have no option to assign decimal places in the Formatting panel BUT in the popup it displays as a 6 decimal place number 2453.000000.  There is no arcade expression in play here either.
I have no idea how this is possible.  Any help would be appreciated and sorry for the horrible graphic.  It likely grabs attention but not a good thing in this case 🙄. Data is a little sensitive and can't be posted.
Thanks in advance,
GR
ChrisUnderwood
Hello @GregReinecke , I've tried this on my ArcGIS Online and it seems to work correctly for me. Is your Schools data a Hosted Feature Layer, or does it Reference an external database etc. If so, please can you give us all the details and versions of that external source.
ChrisUnderwood
GregReinecke
Thanks Chris. It’s a hosted feature layer populated from a shapefile using Update. I checked the shapefile in another GIS and as expected that zipcode is a string/text. I’m sure it’s something on my end so I built an expression to solve my popup issue. No need to burn any more cycles. Thanks again.
