Attempting to overwrite feature layer with related table.
4574
8
07-23-2021 08:40 AM
Labels (2)
JulesBarrett
StatusMessage: Server Response: ERROR: code:400, Unable to delete item. This service item has a related Service item, Bad syntax in request.
Status: InProgress StatusMessage: Publishing tool execution failed
I have tried multiple times to overwrite this feature layer in AGOL.  I have 6 views created from the original feature layer.  I have overwritten this in the past, so cannot see what is different.  I have read other posts and followed their suggestions
  • move to root folder
  • disable sync
Nothing seems to work.  Please advise.  Thank you.
GeeteshSingh7
Esri Alum
If the layer has a view layer associated with it, which is created from Join operations (Analysis > Summarize Data > Join Features > Create results as hosted feature layer view). Then, this error is expected.
To resolve this, delete the view layer.
JoshBerna
Thank you so much for this response, I thought the issue was with my related table and thus relationship class, but it was actually a hosted view layer for the specific feature layer. I was about to give up and publish a new item, which would have involved me rebuilding a large experience app and web map, and this comment saved me so much time. Thank you!
YoavRappaport3
Hi I'm wondering if there have been any updates to this feature. I have a view based on a join. When i overwrite the joined table, the table is corrupted.
Jessica_S
Hi! Bit of a late reply, but there is a limitation regarding overwriting features in ArcGIS Online from ArcGIS Pro. As Geetesh mentioned above, "Joined View" layers will cause this error, as well as any view layers with Areas of Interest defined within them.
As a workaround, the view layers need to be deleted. Then, the hosted feature layer can be overwritten from ArcGIS Pro and the views regenerated. A big thing to note: With the introduction of the Recycle Bin, when the option has been turned on, deleted items will be sent there unless specifically marked for permanent deletion. While in the Recycle Bin, items still technically exist within the organization and will continue to consume storage space, as well as remain "tied" to anything they were originally a part of. So in order for the workaround to actually work, the view layers will need to be either permanently deleted during the initial deletion process or permanently deleted from the Recycle Bin.
Here's some more information on the error specifically, as well as other general limitations to overwriting:
mzhang
@Jessica_S Better late than never--THANK YOU for noting that view layers with Areas of Interest will cause the error! Otherwise, I would've deleted and recreated my view layers without figuring out the problem was and likely would've run into the error again. Instead, I only had to delete the Areas of Interest, which I now realize I don't actually need for my view layers. Also, thanks for noting how the Recycle Bin can affect things.
It would be helpful if the Areas of Interest causing the issue was noted in the technical support page for the error. I found that one first but was confused why I was getting the error when my view layer was not created using the Join Features tool.
Jessica_S
Not a problem, glad I could help!
With technical articles like that (and I believe with most of our documentation), there's an option to provide feedback either on the upper right-hand side or at the bottom of the page. When you have the chance, I highly recommend using that option to let the team know the issues with Areas of Interest and the recycle bin need to be added!
AndreaB_
Hi @Jessica_S ,
Thank you for posting. I just opened an Esri tech support case about this. I do need to have an Area of Interest on my View Layer in AGO. And I've shared the view layer with a group and they are using it and the url of the view layer. Now I need to update my data nightly with a script but the script fails because I can't overwrite my feature layer. I was going to use the script as a workaround for the AGO bug BUG-000171689, "After truncating the feature layer, the visibility scale range of feature layer has been unexpectedly reset at the REST endpoint". https://support.esri.com/en-us/bug/after-truncating-the-feature-layer-the-visibility-scale-bug-00017... . I'm in a very bad circle of no options now. Tech support is going to get back to me - but if you have any ideas, I'm all ears!
Thank you,
Andrea
Jessica_S
Hi @AndreaB_
Just saw this! If it hasn't already been resolved, could you DM the Support case number? I'd be more than happy to take a look!
