1413
04-30-2013 12:35 AM
BelindaOliver1
I have multiple attachments for features. I add the attachments to the geodatabase, but then how do I get the geodatabase into ArcGIS online?
Is there a way to add the attachments in ArcGIS online?
Thaks
MikeMinami
Esri Notable Contributor
Yes, when you add the data to a map and publish to ArcGIS Online as a feature service (via an ArcGIS Online Subscription), the attachments will be part of the service.
Mike
BelindaOliver1
Sorry to be a pain - but I'm still confused.
How do I get a geodatabase in to ARCGis online. The add data option doesn't include geodatabase.
If I change the geodatabase to shapefile I can't have the multiple attachments.
Many many thanks
MikeMinami
You can't publish an entire geodatabase to ArcGIS Online. You can author a map in ArcMap that contains a layer or layers that reference the data in your geodatabase. The layers can have attachments. Then from the File menu, you choose Share as. You'll need to have signed in to your ArcGIS Online for Organizations account. This ability does not exist if you don't have a paid subscription to ArcGIS Online.
http://resources.arcgis.com/en/help/main/10.1/#/Publishing_a_hosted_feature_service_using_an_ArcMap_...
Mike
