Attachments() Function in Web Map Symbology
2890
6
12-29-2023 04:47 AM
Tim-Woodfield
I am trying to set up an arcade expression in the layer symbology that will differentiate features with and without attachments. The Count(Attachments($feature)) part works great in a popup attribute expression and returns the necessary values but I am getting an error when trying to use the same code in the symbology expression. It is saying 'Attachments' is not defined.
Here's my code:
If(Count(Attachments($feature)) > 0) {
      // if count is greater than zero there are attachments
      return 'Has Attachments'
  } else {
      // otherwise the feature has been inspected but missing photos
      return 'No Attachments'
 The funny part is, if I click run to test, it gives me the correct output but the Done button is grayed out.
rwrenner_esri
Esri Alum
I'm seeing the same thing in Map Viewer on a layer with attachments enabled. I'd recommend opening a tech support ticket to get this addressed.
Based on what I'm seeing in the blog post below, it appears using Attachments() for symbology did work at one point in Map Viewer Classic but it no longer seems to work there either (returns "attachments is not available").
https://www.esri.com/arcgis-blog/products/arcgis-online/mapping/visualize-your-attachments-in-arcgis...
Tim-Woodfield
Thank you for the feedback! I'll submit a ticket
DarraghOSullivan
Was this ever resolved? I'm finding the same issue ...
AlainaEllis1
Map Viewer still doesn't allow for the Attachments field to be used in symbology; however, I have begun creating a field called something like "ItemsAttached" and calculating that field in AGOL using Arcade to say 0 if there are none and then 1 for a yes.
Here is the arcade that I use when calculating:
var hasAttachments = Count(Attachments($feature)) > 0;
IIf(hasAttachments, 1, 0);
AnnaJose
It's 2026, and still can't visualize using Attachment function, very disappointing, since it used to be possible
Boyang_Wang
First time Arcade user here trying to do the same. If Done button is greyed out, does that mean the code is incomplete?
