ArgGis online - WebApp/WebMap
4837
15
11-22-2016 03:35 PM
CatarinaFerreira
Hi! Me and my group at the University of Gent are developing a project; we're making an WebApp Online on ArcGis, we added quite some layers, but now we want them to appear just when selected! How can we do this? Also, when doing the apresentation, we'd like the Webapp to appear with less zoom, I mean, show both the USA & Europe coast + UK + Iceland for example, instead of showing just the Belgian coast. I installed the ArcGis Desktop, but still can't figure it out...
DerekLaw
Esri Esteemed Contributor
Hi Catarina,
First, you'll need to create an ArcGIS Online account. You should check with your university if they might already have an ArcGIS Online organization you can join, or you can create a free 60-day trial account:
http://www.arcgis.com/features/free-trial.html?origin=arcgis
To start creating web apps, I suggest you start here:
Hope this helps,
CatarinaFerreira
As you can read in my question we already did that...
RickeyFight
Are you keeping the map in Arcgis Online or will you have a Javascript application?
On AGOL when you save your map it will open next time at that zoom level.
"but now we want them to appear just when selected! How can we do this?"
Are you asking if you have it turned on (checked)?  or when you click the map the layer appears?
CatarinaFerreira
Hm good question! Well, the assignment is to "develop a set of sensors to integrate in non-manned vessel which sends data via satellite at set intervals. Data should be visualized on a web-based GIS. Sensors have to make use of open source Arduino technology."
So.. we need an online map that can be implemented into a web-application publicly accessible, and so anyone can get updates on the location of the vessel at any given time.
Yes the aim is to click so the layer appears; we have quite many, so it's confusing/useless to have them all at the same time..
DerekLaw
Hi Catarina,
My impression from your original post was that you had only initially explored ArcGIS Online, but had not created an app yet. What app option did you use: the configurable application templates or Web AppBuilder?
The map display extent is meant to be dynamic, but you can define spatial bookmarks in the ArcGIS Online map viewer. In Web AppBuilder, you can also limit the scale that an be zoomed to - this setting is found on the Map tab.
As Rickey said in his post, you can control when the layers appear in the map display by clicking them on/off in the table of contents of the web map in the ArcGIS Online map viewer. In Web AppBuilder, you can further control when layers appear with the LayerList widget.
Hope this helps,
CatarinaFerreira
Do you mind if I give you the credentials to log in in ArcGis so you can check? Sorry it's because we are really running out of time and it's confusing for me, especially under pressure and with so many classes
CatarinaFerreira
"you can further control when layers appear with the LayerList widget"
How? And they must be all checked?
They are at least 18 layers!
RickeyFight
As you can see in my two images, the layers that are checked on show in the webapp.
AGOL map
Webapp
Webapp Config
CatarinaFerreira
Ok think I got it.. what about sharing the APP with everyone? It ask to login in ArcGis in order to see it.
