ArcGISOnline Assistant not showing all content
845
03-21-2023 04:17 PM
sgambrel_Bouldercounty
I need to use ArcGIS Online Assistant to re-source some web maps that are using WMS's for a data source.  When I navigate to the group where this content is shared, I only get results up to those starting with "P" (I assume the first 100 results?).  I've been able to update several web maps but the remaining maps that I need to update are later in the alphabet.  I don't see a way to continue past the first 100 results or re-sort into a different order or sort by date or otherwise access those web maps.  The only way I can see to locate these web maps is to manually search the full and exact title of the map, which is arduous.  Is there a better way to access this content?
Thanks!
Sean
AdrianWelsh
MVP Honored Contributor
Sean, I am not sure which ArcGIS Online Assistant you're using but have you tried using the 'other' one?
This is the original one: https://ago-assistant.esri.com/
This is the new one: https://assistant.esri-ps.com/signin
Oh!  I was using the original one.  I'll give the new one a shot.  Thanks!
