ArcGIS Tracks- Track Lines not showing up in underlying service but appear in Track Viewer
329
2 weeks ago
Amanda__Huber
MVP Regular Contributor
It appears we can see our tracks from a recent flight in the Track Viewer, but when looking at the underlying service these track lines appear to be missing. There are no filters on the map/data
Track ViewerTrack Lines Esri Service
Does anyone have any insight into why this would happen? We have two weeks until these lines disappear and we need to pull the data somehow into our backup.
Amanda Huber
RussRoberts
Esri Notable Contributor
Are you able to share the layer to a group an invite russell_jsapi to the group and I can try and take a look?
Amanda__Huber
Hi Russ,
Thanks for your response and for looking into this. I just added you to our "Esri Tech Support 2.0" group and shared the service layer.
Let me know if you need anything else.
Best,
Amanda Huber
RussRoberts
Still looking into this one but something we noticed for the section where its not showing up looks like quick capture and field maps were used and collecting points on the same track for the same user.
One thing to note the track viewer generates the line using the points while Map Viewer is leveraging the service to to show the track line from the line layer. When I check the service the lines shown in MV are the ones for that layer on the service. Something we are looking at if the double app + account maybe caused an issue with the line generation.
Amanda__Huber
Hi @RussRoberts
Thanks for looking into this further. We were collecting tracks simultaneously via two devices due to QuickCapture's display limitation at this time.  We had QuickCapture and Field Maps running for the same user during the Aerial collection.
To clarify, do you know why Map Viewer and Track Viewer would have a difference in how these "double" tracks are viewed? We currerntly have an Esri support case open for this, but would like to know if this is a bug or known limitation by the developers.
Amanda Hu
