ArcGIS Tracker
1099
01-19-2021 02:14 AM
EnriqueAlfonso
I´ve been using ArcGIS Tracker since November, however when I looked at the attribute table there is data just from the 8th december, there is no data from november.
It is as if data were automatically deleted because it had a capacity limit or a time limit.
Does anyone know about this problem?
Thank you in advance.
Enrique.
DeniseTingstad1
Hi Enrique,
If Tracker was just enabled through ArcGIS Online the data is kept for 30 days.  If you are going through ArcGIS enterprise you are able to chose the length of time that you want to keep the data.
EnriqueAlfonso
Hi Denise,
Thank you for your answer.
