Hello all!
I'm trying to publish a Feature Service with a SDE View, witch joins a feature class and a table, but the data doesn't load on map. There's any trick to do this?
Thanks!
It could be a database permissions issue. Maybe the user has access to the feature class but not the table.
Ok Randy. It´s possible. I'll check this and post the results... thanks!
